Sep 15th, 2026, 11:54pm
128b/130b encoding in PCI-Express Gen3 (Read 12035 times)
neoflash
Mixed-Signal
Designer
Sep 19th, 2010, 12:15pm
The change in encoding schemes also includes a scrambling/descrambling algorithm as follows:
x23 + x21 + x16 + x8 + x5 + x2 + 1.
It is quite interesting that this scrambling scheme only use x23 as the most significant bit, while introduced 6 feedback nodes. Compared with x59+x38+1 in 64b/66b scrambler, it is very different.
My question is that whether that many (6) feedback nodes will worsen the error propagate? (each error bit has 6 chances to ruin other bits.)
Welcome to join this discussion.
Re: 128b/130b encoding in PCI-Express Gen3
Reply #1 - Sep 24th, 2010, 2:05pm
Haven't studied it, but you are going to need the whole story, coding structures, bandwidth, ECC methods, etc.
Coding theory and ECC is a field of math/engineering that can get a bit "too interesting" for some. I went that path for a while in the field of disk drives, the coding and ECC things there are pretty complex.
What you mention of the capability to "mess up" 6 other bits does not take into account the detection scheme and the weighting of each delay tap. I expect whats getting used is a Viterbi detector and some for of "partial response" with "maximum likelihood" detection...The contribution from a single bit is actually spread across several time windows and has to be properly weighted in (or out) of the adjacent windows.
Anyhow it becomes a communication channel problem with needs to look at the model end to end, Some things will be in the PHY levels but a lot is not.
neoflash
Mixed-Signal
Designer
Reply #2 - Sep 13th, 2011, 3:47pm
I see. Thanks.
