Jul 17th, 2024, 3:35pm
How to simulate conductance at node in given  circuit (Read 2561 times)
saam
india
Sep 20th, 2010, 1:39am
can anyone tell how to find the conductance at node in cadence ...
Re: How to simulate conductance at node in given  circuit
Reply #1 - Sep 20th, 2010, 2:36am
Surya,
  This should have been posted to the circuit simulation since your
question is tool related. You also refer to the tool that you seeking
help with ADE, Spectre, ...
  Have you connecting an ac current voltage source at the target
node and forced an ac current, mag=1?  Note: the other sources
need to be disabled for this test.
  Question for you, how would you calculate the conductance from
the response?
        Best Regards
saam
india
Reply #2 - Sep 22nd, 2010, 1:27am
Hello Sheldon
        Thank u for reply.
Actually in my circuit i have to find conductance at input node and output node,,and i connected Rf input source and output source at that nodes respectively.
   and i done S-parameter analysis, in that from Y-parameter i found Y11 and Y22. I thought these are the conductance at input node and output node.
Can you tel me is my way of procedure is correct or not ..
                                                 Thank u
                                                 surya
Reply #3 - Sep 22nd, 2010, 6:48am
saam wrote on Sep 22nd, 2010, 1:27am:
Your approach based on S-parameter Analysis is appropriate if "port" never affects DC operation point of circuits.
See http://www.designers-guide.org/Forum/YaBB.pl?num=1240334878/16#16
If not, your approach is not appropriate.
