Aug 2nd, 2024, 11:23pm
coupled capacitance for differential signal layout (Read 4678 times)
newic
Sep 23rd, 2010, 3:50am
As i know, differential signal lines should be drawn as close as possible in the layout. The extracted coupled capacitance (CC) will be large due to close proximity. Is it ok?  In the parasitic net table, the total cap (C+CC) value will be dominant by CC value. Am i doing the right thing?
love_analog
Re: coupled capacitance for differential signal layout
Reply #1 - Oct 11th, 2010, 6:24am
You place diff signals close together so that noise coupling on both lines is the same.
If you are worried about CC, you can place them further apart. Just make sure there is no differential noise coupling. One way is to shield both lines.
loveanalog.blogspot.com
The Power of Analog
rfmagic
Reply #2 - Oct 11th, 2010, 8:10am
As long as the coupled capacitance CC is taken into acount (as you probably did) you are doing the right thing. Just make sure that both differential lines follow route i.e. any potential noise should be coupled to both lines
newic
Reply #3 - Oct 12th, 2010, 5:15am
Which approach is better?
1. put differential lines close together and get large CC
2. put differential lines apart like 2x min spacing, and get lower CC
raja.cedt
Reply #4 - Oct 12th, 2010, 6:11am
i feel put as near as posb and try to route a thin vss line in between
Thanks.
rfmagic
Reply #5 - Oct 12th, 2010, 7:06am
I agree. put them as close as possible but in your simulation add CC and dont forget the capacitance to gnd
RobG
Bozeman, MT
Reply #6 - Oct 12th, 2010, 7:52am
I've never liked the ground line between the signal lines because your cap increases if you keep the separation the same.
As a sort-of oldtimer, I was stunned by how much the sidewall cap dominates the overall cap in modern processes. Metal sheet resistance is very large too.
Has anyone seen studies of how close lines have to be before differential noise becomes an issue? Seems like it would be on the order of microns given older processes seemed to work.
rg
HdrChopper
Reply #7 - Oct 12th, 2010, 5:34pm
newic wrote on Oct 12th, 2010, 5:15am:
Having a large CC migth not be harmful, depending on the nature of your differential signal: if your signal is a low pass one most probably that CC will help filter it out and it ends up being beneficial. On the other hand if your diff signal is  high frequency and / or diff clock signals you should look for minimizing CC.
Best
Tosei
Keep it simple
