Aug 2nd, 2024, 1:26pm
MiM cap vs transistor decoupled cap (Read 2444 times)
newic
Sep 23rd, 2010, 4:10am
For a given area like 10u x 10u, I found out that the transistor decoupled cap (with s & d tied together) has larger capacitance value than MiM cap for the high gate voltage around vcc. Is it better to use transistor cap to form decoupled cap rather than MiM cap.
raja.cedt
Re: MiM cap vs transistor decoupled cap
Reply #1 - Sep 23rd, 2010, 5:43am
hi,
MIM cap only preferred only in case of high linearity requirement. For decap i guess you don't have any such requirement.
Thanks.
newic
Reply #2 - Sep 23rd, 2010, 6:19pm
Is it normal that the transistor cap capacitance value is much larger than MiM cap value. MiM is formed by insulator, which is supposedly have large dielectric, thereby larger cap value. That's why I always presume MiM will have larger capacitance value.
swolf
Reply #3 - Sep 24th, 2010, 7:57am
yes, the gate oxide is usually thinner than the insulator in the mim.
raja.cedt
Reply #4 - Sep 24th, 2010, 10:35am
no man, MIM has very less value because distance between two metals is depends on the inter metal thick-ness where as mos-cap has very thin oxide hence very high cap.
Thanks.
carlgrace
Berkeley, CA
Reply #5 - Sep 24th, 2010, 4:00pm
If your process allows it, you can get maximum bypass cap density by laying out a MIMcap on top of the MOScap to make a bypass cell.  Be careful about the Q of the bypass cap, you may need to add a small resistor in series with the bypass cap.  To know, you will have to simulate with the expected amount of bypass cap and the expected inductance in the power rail.
love_analog
Reply #6 - Oct 11th, 2010, 6:14am
NewIC
What process technology is this in. I have heard that in finer geometries (32nm etc), the MIM cap have higher resistance. In which case Q may not be an issue.
Otherwise whatever carlgrace said is bang on.
loveanalog.blogspot.com
The Power of Analog
rfmagic
Reply #7 - Oct 11th, 2010, 8:17am
usually for low noise design MIM is better. MOS CAP has higher noise than MIM
RobG
Bozeman, MT
Reply #8 - Oct 11th, 2010, 12:52pm
rfmagic wrote on Oct 11th, 2010, 8:17am:
And of course the capacitance of MOS caps is strongly dependent on bias voltage so that is the main reason why it isn't used more. It makes a good decoupling cap, however.
rg
ACWWong
Oxford, UK
Reply #9 - Oct 11th, 2010, 1:57pm
yes moscap makes good decoupling cap in terms of density, but as well as voltage dependancy, they leak current which is heavily temperature dependant.... this may or may not be a problem in your application.
newic
Reply #10 - Oct 12th, 2010, 5:08am
thank you Smiley
ci
Reply #11 - Oct 12th, 2010, 11:20am
One additional thought:
MOS caps have one of the plate capacitively coupled to the substrate, so what you have there are actually two capacitors in series.  You decouple two voltage supply rails but you couple one of them with the substrate through this additional capacitor.  So depending on the design you may inject noise into substrate (if that supply rail is noisy) or you may capture noise from the substrate into a sensitive supply rail.
Cosmin Iorga, Ph.D.
founder NoiseCoupling.com
http://www.noisecoupling.com
newic
Reply #12 - Oct 14th, 2010, 6:36am
thank you Smiley
