Aug 2nd, 2024, 11:17am
Decap size (Read 2207 times)
newic
Decap size
Oct 14th, 2010, 6:44am
I use transistor to form decouple cap (decap) for power supply vdd.
what are the differences between a single large decap with size 50u x 50u (width x length)  and multple decap with smaller size but same area in total, suh as 25 10u x 10u decap. Which one is better?
The differences from aspect like frequency response / speed, ESR, Rg, leakage etc..
rfmagic
Re: Decap size
Reply #1 - Oct 14th, 2010, 7:46am
The only limitation is set by the PDK design rules that you use. usually we use the maximum WxL of the MIM and MOSCAP for decoupling
RobG
Bozeman, MT
Re: Decap size
Reply #2 - Oct 14th, 2010, 8:47am
Shorter lengths will be faster, but you might want to lower the Q with longer lengths. I asked the same question myself and finally got it figured out with some help. Click here for the thread.
newic
Re: Decap size
Reply #3 - Oct 14th, 2010, 6:10pm
How does the model looks like?? There must be a Rg & Rs/d as ESR of the cap.
for a 50u x 50u (max size), the worst case resistance Rg & Rs/d would be at the centre of the cap. is it true ??
would check on the freq response and see...
