carlgrace
If your process allows it, you can get maximum bypass cap density by laying out a MIMcap on top of the MOScap to make a bypass cell. Be careful about the Q of the bypass cap, you may need to add a small resistor in series with the bypass cap. To know, you will have to simulate with the expected amount of bypass cap and the expected inductance in the power rail.
