Now , DUT has I/O (bi-directional) port w/t pull up or pull down resister.
So, i wana check this function of this I/O.
plz refer to my appended file to show testbench.
-JTAG task(verilog-D)
-LevelShifter( up to I/O voltage )
-DUT
for checking behavior of these I/O , at first i make module on VAMS.
module LS_ams( Ain , A5vout );
input Ain;
output A5vout;
electrical Ain,A5vout;
real temp;
analog begin
@(cross(V(Ain)-0.7,0));
if(V(Ain)>0.1) temp = 1;
else temp=0;
V(A5vout) <+ 5*transition(temp,0,1n,1n);
about this, so many questions i have... at first, i want 2 know 2 question as first step.1)
Hiz case How does connect function works when JTAG task(verilog-D) drive Hiz?
Does connect function which tool insert automatically translate Hiz directly ?
now it seems so( trans Hiz ) on my simulation results.
my understanding is correct?
2)
output impedance how should i care for output impedance of this vams module.
now it seems so low impedance on my simulation.
cos, i can't fond pull up function of I/O.
plz let me know...
