Aug 5th, 2024, 3:11am
Re: Snapback in LDMOS (Read 3161 times)
ujwal
Oct 11th, 2010, 3:45am
I am trying to write a compact model for snapback effect in LDMOS. KCL and KVL for  the Equivalent circuit results in a node voltage of the form :
V(n,0) = C1+ C2*exp(V(n,0)/Vt)    ; (C1>>C2)
This has two solutions for V(n,0) . What do i have to do to get the higher value solution? My code in VerilogA always gives me the lower value solution for V(n,0 ) which is close to trivial solution.
Ujwal
