ujwal
I am trying to write a compact model for snapback effect in LDMOS. KCL and KVL for the Equivalent circuit results in a node voltage of the form : V(n,0) = C1+ C2*exp(V(n,0)/Vt) ; (C1>>C2)
This has two solutions for V(n,0) . What do i have to do to get the higher value solution? My code in VerilogA always gives me the lower value solution for V(n,0 ) which is close to trivial solution.
Ujwal
