aaron_do
Is this for the input stage? I don't think you would want to use active inductors, since they will add noise directly to the input. You can also forget about integrated inductors since as you say they are too large. For such low frequency you probably have to use common-gate, resistive shunt-feedback, or simply an off-chip matching network.
cheers, Aaron
