Aug 15th, 2024, 6:46pm
Pages: 1 2
noise simulation of dynamic latched comparator in Spectre (Read 27733 times)
Raymond Yu
Singapore
Oct 18th, 2010, 6:19pm
Hello designers,
I understand there was already some discussion of this topic on the forum, but looks like none of them can be comprehensive.  Appreciate that you can put thought over here make this topic beneficial to most of the users
I am simply referring to the dynamic latched comparator (preamp + regenerative latch) in which a clock/strobe signal is used to trigger the regeneration. As I know, accurate INPUT-referred noise simulation for such circuit is always difficult for the designers. The following are the solutions generally adopted by the designers
1) Ignore the noise from regenerative latch, only taking care of the noise of preamp or try to make sure that the noise from latch is negligible. I think this is quite common approach in the old days, but becoming more risky in the designs in which the preamp does not have enough gain, or even there is no preamp.
2) Use transient noise option. This is the one I am currently using, but extremely time-consuming and need more effort on the post-processing on the simulation result. Here are the steps, assuming a input-referred noise with Gaussian distribution
 2.a: determine the comparator offset (systematic only, random mismatch not introduced yet) using a similar method as in http://www.designers-guide.org/Analysis/comparator.pdf and exclude its effect in the simulations afterward.
 2.b: After excluding the effect of offset, impose a small difference on the comparator inputs, with transient noise turning on, run a quite long time transient simulation (>1000 clk cycles). Due to the existence of transience noise, the comparator output can be both HIGH or LOW. The probability of logic HIGH is a function of the noise level. By sweeping the input difference, a cumulative distribution curve can be obtained, as in the example in the attachment (ref: Nuzzo, De Bernardinis, Terreni & Van der Plas, "Noise Analysis of Regenerative Comparators for Reconfigurable ADC Architectures," TCAS, 2008). Buy curve fitting in Matlab, I can get the standard deviation (σ) of the Gaussian noise distribution.
The advantage of this method is in that similar testbench can be used in the measurement to compare with simulation. But as I mentioned, quite time-consuming (at least 20 swept points, >1000 clk cycles per point), and need post-processing in Matlab.
3) PSS/PNOISE. I am quite familiar with the PSS/PNOISE setup as in the sw-cap filter and VCO circuits. But met significant difficulties in dynamic latched comparator simulation. What I am currently doing is as below
 3.a: Given a clock frequency Fclk, a square-wave comparator input with frequency of Fclk/2 is applied.
 3.b: A toggled comparator output with frequency Fclk/2 can be obtained.
 3.c: By PSS/PNOISE, a output noise/jitter can be obtained, even though I am not quite sure whether it makes sense.
 3.d: Did not find way to read out the input-referred noise yet, as I did not know how to determine the gain of such comparator in Spectre, as it is highly time-varying.
Actually I am not confident with this setup, does anybody think it is possible to get a input-referred noise for the comparator directly? Any suggestion is highly appreciated.
Re: noise simulation of dynamic latched comparator in Spectre
Reply #1 - Oct 18th, 2010, 10:27pm
Concerning method 3 (PSS/PNoise). You say you had difficulties with these simulations, can you describe the problem you had.
Concerning the input referred noise, generally if you specify the input source to the noise analysis, it naturally computes the input referred noise. Is that not working?
Reply #2 - Oct 19th, 2010, 7:11am
Raymond Yu wrote on Oct 18th, 2010, 6:19pm:
I don't think so.
If your interests are quantities averaged over one period, there is no reason why you can't adopt PSS/PAC and PSS/Pnoise(sources).
Conventional AC and Noise analysis at specific time during Transient Analysis are also valuable for your application.
http://www.designers-guide.org/Forum/YaBB.pl?num=1272909056
Raymond Yu
Singapore
Reply #3 - Oct 21st, 2010, 6:59am
Ken Kundert wrote on Oct 18th, 2010, 10:27pm:
Hi Ken,
Thanks for the reply. I agree that from the PSS/PNOISE simulation, whenever you set the input noise, you can read the input-referred noise. But my concern is like this, we both know that for normal continuous-time circuits(amplifiers, filters...) and sw-cap circuits, you can always obtain a "gain" with AC or PAC simulation and cross-check with the ratio of  output and input noise. But for circuits which doesn't have a steady state, like dynamic latched comparator, how should you define a gain for them?
The reason I started  this discussion is in that, I am quite confident with the result given by the method 2 as in my primary post, but it is quite different from the one obtained by PSS/PNOISE. Therefore, I wondered whether I did something wrong, or any specific issue I should pay attention to in the PSS/PNOISE simulation of such comparator. Thank again
Raymond Yu
Singapore
Reply #4 - Oct 21st, 2010, 7:07am
pancho_hideboo wrote on Oct 19th, 2010, 7:11am:
I don't think so.
Please leave the post link(s) here, thanks.
Again, I tried to figure out how the gain is defined in such circuit.
I will try this and let you know the outcome, thanks
vp1953
Reply #5 - Oct 21st, 2010, 6:27pm
Hi Raymond,
Why is there a need to measure input referred noise? I mean could you not compare the results of PSS/PNOISE and transient noise just using the output noise/jitter.
While one could conjecture on various way to measure input referred noise, I am not sure if any of them are physically meaningful or insightful for the reason you stated that the latch has a varying gain.
I am wondering why your latch turns HIGH with a small difference voltage applied to its input. Is the small difference voltage such that it can trip with a small noise voltage arising say from the gates of input transistors? If you can post a schematic of your setup that would be great.
Raymond Yu
Singapore
Reply #6 - Oct 22nd, 2010, 1:12am
vp1953 wrote on Oct 21st, 2010, 6:27pm:
Hi Raymond,
The comparator will be used in a swiched-cap SAR ADC, input-referred noise is needed to decide the design constraints for the ADC.
I agree that for some applications in which the BER is the main concern for instance, taking care of noise/jitter at the output is almost good enough.
The picture I attached is a little misleading as I failed to show the label of Y-axis. It is actually the probability of output "HIGH"in stead of voltage. Sorry for the inconvenience caused.
Reply #7 - Oct 22nd, 2010, 2:32am
You have four options as definition of Gain.
  (1) Gain during Sample mode(Comparate mode)
  (2) Gain at transition from Sample mode to Latched mode.
  (3) Gain during Latched mode
  (4) Gain averaged over one clock period.
Here you have to treat an input signal as large.
If you treat an input signal as small, (3) will be same as (2).
Raymond Yu wrote on Oct 21st, 2010, 6:59am:
Dynamic latched comparator surely have steady state, as far as both latched clock and input signal are periodic.
Here they don't have to be co-periodic.
If they are co-periodic, you can adopt PSS/PAC/Pnoise.
If they are not co-periodic, you have to use QPSS/QPAC/QPnoise.
Show me your netlists regarding analysis statements and signal source definitions both for PSS/Pnoise and Transient-Noise analyses.
Transient-Noise Analysis is no more than Monte Carlo trial.
You can get same statistical characteristics by small signal noise analysis, if you adopt small signal noise analysis correctly and can understand its results correctly.
This is similar to Bit Error Simulation for AM or ASK system.
On the other hand, we have to rely on Monte Carlo true large signal analysis to evaluate BER of PM or FM system.
You can't do BER simulation using small signal analysis.
Simply you can estimate BER from results of small signal noise analysis for AM system.
http://www.designers-guide.org/Forum/YaBB.pl?num=1259714206/2#2
Raymond Yu wrote on Oct 22nd, 2010, 1:12am:
See http://www.designers-guide.org/Forum/YaBB.pl?num=1258339986/48#48
« Last Edit: Feb 5th, 2011, 10:34am by Ken Kundert »
Taimur Rabuske
Lisbon, PT
Reply #8 - Nov 26th, 2010, 12:31pm
I am quite sure that Mr. pancho_hideboo didn't get the whole picture.
The estimation of noise in latched comparator is not a trivial task, and there are just 2 efficient approaches I know. One of them was cited before, and is from Nuzzo et al. The other one is also from TCAS-1, search for "Simulation and Analysis of Random Decision Errors
in Clocked Comparators", by Kim, J. et al. This paper will answer your questions about time-varying gain.
Again, this is not a straightforward procedure, and will take some amount of scripting and post-processing. So, in opposition to what Mr.
pancho said, this topic can be useful to a lot of people that are actually able to understand the problem.
Taimur Rabuske
Lisbon, PT
Reply #9 - Nov 27th, 2010, 5:37am
Well, if the procedure is that straightforward, I would like to know it. Nowadays, I am relying on 100's of PAC simulations and a huge ammount of post-processing to get the input-referred noise, following the guidelines of Mr. Jaeha Kim paper.
So, maybe if Mr. pancho has a better approach, I would definitely enjoy to have a step-by-step walkthrough.
wghabrial
Reply #10 - Mar 16th, 2011, 11:21am
Hi
I am doing exactly the same simulation that Raymond is going.
Transient Noise Method
I apply a dc voltage to the comparator input and clock the comparator many times and calculate the probability of getting '1'. Then I repeat this by sweeping the input and drawing the probability density function. Fitting it to the erf function produces the equivalent input noise.
This method is logical and straightforward.
PNoise method
I apply a sine wave at the one of the comparator inputs and a threshold voltage on the other input. I chose the input frequency to be half the clock frequency so everything is periodic. Then I measure the jitter (Jc) at the zero crossing of the input. I then multiply this jitter by the slope of the signal (which is the frequency) to get the equivalent input noise.
The 2 results do not match and I am not sure which one is the correct one. I was wondering if someone has figured this out and has a reliable method of doing it.
weber8722
Reply #11 - Oct 5th, 2012, 1:15am
using transient noise is by far the best method. Spectre pnoise sim with jitter analysis is also fine, and from jitter you can calculate back the effective voltage noise. As long no bit errors occur from noise pnoise and tran noise are pretty much in synch  :).
Generally the jitter and noise depends also on input voltage overdrive level!!! If this is too low SNR is too low and BER rises dramatically and pnoise (green curve) would not show this effect, only tran noise does it (red).
Bye Stephan
Reply #12 - Oct 22nd, 2012, 6:01am
Hi Stephan,
Your plot is interesting. I want to know how you plot the spectrum of JitterriseRMS (that curve in red)? Do you run transient noise simulation and do DFT on the jitter result?
Yawei
Reply #13 - Oct 23rd, 2012, 5:51am
Hi Stephan,
As what you said, the jitter and noise depends also on input voltage overdrive level. I run a few simulations with different input level, the resulted jitter varies very much. It seems that pnoise method is not easy to use for measure the input noise of latch/comparator. What is your setup for the simulation? I have some trouble in my computer. I will paste a few plots tomorrow.
Yawei
weber8722
Reply #14 - Nov 22nd, 2012, 2:29am
Hi Yawei,
My tran noise based plot is created quite simple:
as I remember, I run the tran noise for e.g. 1000 periods or more.
Then I use the Viva calculator to get the jitter vs periods.
On this I can calculate the standard deviation which is the RMS jitter. So no DFT is done!!
Bye Stephan
Pages: 1 2
