neoflash
Mixed-Signal Designer
For some reason, spectreRF doesn't want to give me phase noise results in Direct Plot Form. However, it always give me output noise.
When I select phase noise item in GUI, tool tells me that " output nodes of pnoise analysis not saved for pss analysis. As a result, the above selected function cannot be executed."
What can cause this problem?
Thanks, Neo
