Oct 18th, 2025, 11:25am
A high side non-ideal current mirror in Verilog-A? (Read 8424 times)
the_wavefunction
Oct 21st, 2010, 4:21am
One of my circuits in Cadence needed a high performance pmos current mirror and I decided to simulate it initially using Verilog-A.
Essentially, my idea of the mirror circuit was to implement two simple resistive branches with one being the probe and the other, the source. It was also vital that in addition to the mirrored current, the voltage at the output terminal track the input terminal voltage as well.
However, according to simulations, when the current is mirrored properly, the terminal voltage is not and vice versa.
I do realize that in Verilog-A, a branch cannot be both a flow and potential source simultaneously!
So, after numerous revisions the present version of my code looks like this:
`include "constants.vams"
`include "disciplines.vams"
module curr_mirr(srcA, srcB, mrrA, mrrB);
input srcA,srcB;             // source branch
inout mrrA;                     // mrrA, srcA are tied to Vdd externally
output mrrB;                   // mrrA, mrrB - mirror branch
electrical srcA, srcB, mrrA, mrrB;
electrical int;                  // node joining current source and Rmodel
real Rmodel;
analog begin
 @(initial_step) begin
   Rmodel = 10K;
 Rmodel = 10K;
 V(srcA,srcB) <+ I(srcA,srcB) * Rmodel;
 I(mrrA,int) <+ I(srcA,srcB);
 V(int,mrrB) <+ I(int,mrrB) * Rmodel;
A simulation of this code tracks the current, but not the terminal voltage.
In other words:  V(srcB) ≠ V(mrrB),  which is against the desired result.
Any suggestions or opinions on this are utmost welcome!
jerome_ams
Re: A high side non-ideal current mirror in Verilog-A?
Reply #1 - Oct 26th, 2010, 8:04am
Here my first-guess suggestion: could the use of Verilog-AMS, rather than Verilog-A, be an option for you?
Using Verilog-AMS, the modeling will be quite staight forward (voltage-current duality supported)
Hope it helps,
Jerome
the_wavefunction
Reply #2 - Oct 27th, 2010, 12:53am
Hi Jerome,
Good to know from you that it can be effected in Verilog-AMS.
But I found out that I can't avail myself of Verilog-AMS here!
jerome_ams
Reply #3 - Oct 27th, 2010, 1:46am
Sorry, I have to reconsider my answer. At the first glance I have just picked up this sentence:
and was reacting on it. But I misread your point.
VerilogA DOES allow you to describe the voltage-current duality. VerilogAMS will just allow you on top of that to describe digital discrete events.
(VerilogAMS can basically be seen as the merger of VerilogA and Verilog-HDL).
Let me come back to you in another post and try to adress your question more effectively
Reply #4 - Oct 27th, 2010, 2:01am
A current mirror should only set its output current. The output voltage will be determined by the load.
jerome_ams
Reply #5 - Oct 27th, 2010, 2:32am
hi again,
I agree with Ken.
The way we usually implement a current mirror model is the following:
1) the current flowing in the sink branch (a resistor) is monitored. It is the target current
2) this target current might be multiplied by a gain factor and then passed as a parameter to a current source. The current source is usually described as a "real" one, meaning its voltage drop (Vdrop) between positive and negative nodes is checked. If it drops below a certain value, the current source reduces its current (sufficient voltage should be there to allow full current to flow)
=> the potential at the output node of the current source is determined by the load connected to the current source, not by the voltage on the sink branch
Cheers,
Jerome
the_wavefunction
Reply #6 - Oct 27th, 2010, 9:05am
Hi Ken & Jerome,
Thanks to your comments, I now modified the inputs of the subsequent stage (which is actually a Verilog-A transimp amplifier) to suit the desired operating levels.
I was initially thinking only on the lines of advanced cascoded current mirrors, where generally the Vds matching of both mosfets are sought after, and I told myself that there has to be some model to mimic that. But I missed the point that, there as well the drain voltage at the cascoded output changes anyway!
Thanks once again for pulling me on the right track  :)
