Jul 16th, 2024, 6:48am
diode (Read 2965 times)
SAM_K
diode
Nov 02nd, 2010, 11:20pm
how do i increse the scalability(varying w,l etc.) of the four regions of a diode if im doing an empirical fit with decent accuracy in VeriolgA.
Re: diode
Reply #1 - Nov 4th, 2010, 5:50am
SAM_K wrote on Nov 2nd, 2010, 11:20pm:
in VeriolgA.
I'm not quite sure how Verilog-A is involved here -- do you have a compact model description of a diode written in Verilog-A?
If you're trying to fit four regions, then you'd better have equations for the four different regions.  Diode models built into commercial simulators typically have a couple saturation currents: forward, reverse/breakdown, tunneling.
jerome_ams
Re: diode
Reply #2 - Nov 8th, 2010, 7:30am
yes I ll go in this direction as well:
=> I would take this descripion as a starting point:
http://www.designers-guide.org/VerilogAMS/semiconductors/diode/diode.va
, and implement all the features I d need using equations derived from the physics to have a parametrizable model.
Cheers,
Jerome
