Jul 16th, 2024, 8:37am
Typical Audio, CD quality Anti aliasing filter (Read 4455 times)
Fernando
Nov 05th, 2010, 4:15pm
I am trying to setup a simulink model of a typical anti-aliasing filter used in audio, CD quality (ie 44Khz sampling rate).
Does anybody know of any reference that provides the coefficients of a typical Laplace transfer function that implements such a filter (including order, type (Bessel, Butterworth, etc)?; I am ok if I get the coefficients for the normalized angular frequency instead.
I want to stress that I am not after an analog filter primer but rather about the Laplace coefficients of an analog filter as close as those used in practice.
Thank you in advance.
ACWWong
Oxford, UK
Re: Typical Audio, CD quality Anti aliasing filter
Reply #1 - Nov 6th, 2010, 12:37pm
since you already using simulink, matlab gives you the transfer functions of butterworth, bessel cheby etc. analog filters
buttap
besselap
etc.
you can get the syntax from using help <command> in matlab.
once you have the poles and zeros you can get the coefficients of the laplace transform of transfer function by using the poly function
buddypoor
Bremen, Germany
Reply #2 - Nov 7th, 2010, 2:29am
Fernando wrote on Nov 5th, 2010, 4:15pm:
Fernando,
do you hear about some powerful filter design programs which are available for free in the web?
buddypoor
Bremen, Germany
Reply #3 - Nov 7th, 2010, 9:35am
Mote than that, I direct your attention to AN699 from Microchip.
