Thank you!
http://fixunix.com/mandriva/123550-problem-libraries.html[jim@jb ~]$ locate libc.so.6
/lib/libc.so.6
/lib64/libc.so.6
[jim@jb ~]$ ls -l /lib/libc.so.6 /lib64/libc.so.6
lrwxrwxrwx 1 root root 11 May 9 12:37 /lib64/libc.so.6 -> libc-2.4.so
lrwxrwxrwx 1 root root 11 May 9 12:37 /lib/libc.so.6 -> libc-2.4.so
[jim@jb ~]$ ls -l /lib64/libc-2.4.so /lib/libc-2.4.so
-rwxr-xr-x 1 root root 1288656 Mar 7 2007 /lib64/libc-2.4.so
-rwxr-xr-x 1 root root 1232576 Mar 7 2007 /lib/libc-2.4.so
Check to see if you have the two libc-2.4.so libraries, and
if the symbolic links are correct.
You may need to link existing libc-2.4.so files to the needed
pathnames, using ln -s /existing/path/file /new/path/file
some one has solved this kind of problem like above.
I don't have the /usr/ius/tools/simvision/lib/libdcapi.so
[root@mml lib]# ls -l ./64bit/libdcapi.so
lrwxrwxrwx 1 root root 37 Nov 16 19:33 ./64bit/libdcapi.so -> ../../simvision/lib/64bit/libdcapi.so
[root@mml lib]# ls -l ../../simvision/lib/64bit/libdcapi.so
ls: ../../simvision/lib/64bit/libdcapi.so: No such file or directory
[root@mml lib]# ls -l ../simvision/lib/libdcapi.so
ls: ../simvision/lib/libdcapi.so: No such file or directory
I DON'T know what to do, so I just
copy /usr/ius/tools/simvision/lib/64bit/libdcapi.so to /usr/ius/tools/simvision/lib/libdcapi.so
and delete ls -l ./64bit/libdcapi.so
then [root@mml lib]# ln -s ../simvision/lib/libdcapi.so ./libdcapi.so
However, I don't solve my problem. I know it is wrong to copy /usr/ius/tools/simvision/lib/64bit/libdcapi.so to /usr/ius/tools/simvision/lib/libdcapi.so.
but, what should I do without /usr/ius/tools/simvision/lib/libdcapi.so?
how can I use "ln -s /existing/path/file /new/path/file" without "/existing/path/file"?
help!!!
