May 17th, 2024, 10:32am
AMS+error encountered during NC elaboration for configuration (Read 13173 times)
mustangyhz
china
Nov 14th, 2010, 12:34am
how to solve this?thanks!
mustangyhz
View Profile mustangyhz 3241568   IP Logged
Re: AMS+error encountered during NC elaboration for configuration
Reply #1 - Nov 15th, 2010, 2:30pm
There is too little information here to even try to help you.
mustangyhz
china
Reply #2 - Nov 15th, 2010, 5:46pm
I am sorry, I have added some information here:
no connection module found:need an input port of discrete discipline logic, and an output port of continuous ciscipline electrical, at instance test.IO.
.clkin(net7), .clkout(net10)
no connection module found:need an input port of continuous discipline electrical, and an output port of discrete discipline logic, at instance test.IO.
mustangyhz
Reply #3 - Nov 15th, 2010, 7:53pm
Mustangyhz,
  AMS is telling you that there are no connect modules. How are you
defining them?
mustangyhz
china
Reply #4 - Nov 15th, 2010, 11:24pm
thank you!
I have solved the problem by adding the connect rules "ConnRules_18V_fll_fast". But there is another problem.when I simulate it. there is an error messeage in the ncsim.log
ncsim: *W,DLCPTH (../cds.lib,11): cds.lib Invalid path '/apps/CDSTools/ASSURA31.lnx86/500/ASSURA317_Base/tools/assura/etc/avtech/avTech
' (cds.lib command ignored).
ncsim: *W,OPOBSO: Obsolete option AMSLIC:  Use AMS license.
ncsim: *W,SST2DC: Unable to load SST2 communication library: /usr/ius/tools/lib/libdcapi.so: cannot open shared object file: No such file or directory or file is not valid ELFCLASS32 library..
how can i solve this problem?
mustangyhz
Reply #5 - Nov 16th, 2010, 5:13am
Mustangyhz -
This is the third separate place you have asked the very same question!!
I think SST2 is a specific output format; perhaps you can look at your settings and choose a different one (PSF?).
You said that you found /usr/ius/tools/lib/libdcapi.so is a symbolic link (->); you should check that the file it points to actually exists.
mustangyhz
china
Reply #6 - Nov 16th, 2010, 5:27am
Thanks for your reply
I do find this file
[root@mml lib]# cd /usr/ius/tools
[root@mml lib]# cd /lib
[root@mml lib]# find ./ -name libdcapi.so
./64bit/libdcapi.so
./libdcapi.so
[root@mml lib]# ls -l ./64bit/libdcapi.so
lrwxrwxrwx  1 root root 37 Nov 16 19:33 ./64bit/libdcapi.so -> ../../simvision/lib/64bit/libdcapi.so
[root@mml lib]# ls -l ./libdcapi.so
lrwxrwxrwx  1 root root 34 Nov 16 19:35 ./libdcapi.so -> ../simvision/lib/64bit/libdcapi.so
help me!!!!!!!!
mustangyhz
Reply #7 - Nov 16th, 2010, 10:56am
mustangyhz wrote on Nov 16th, 2010, 5:27am:
Well, there's a possible problem: the 32bit libdcapi points to the 64bit one under simvision.  I would have expected
rwxrwxrwx  1 root root 34 Nov 16 19:35 ./libdcapi.so -> ../simvision/lib/libdcapi.so
Also, be sure to try
ls -l ../simvision/lib/libdcapi.so
ls -l ../simvision/lib/64bit/libdcapi.so
to see if the file the link points to is actually there!
mustangyhz
china
Reply #8 - Nov 16th, 2010, 4:47pm
1\[root@mml lib]# ls -l ../simvision/lib/libdcapi.so
ls: ../simvision/lib/libdcapi.so: No such file or directory
why should I check this?
2\[root@mml lib]# ls -l ../simvision/lib/64bit/libdcapi.so
-rwxr-xr-x  1 19645 1001 786193 Mar  3  2010 ../simvision/lib/64bit/libdcapi.so
3\[root@mml lib]# ls -l ../../simvision/lib/64bit/libdcapi.so
ls: ../../simvision/lib/64bit/libdcapi.so: No such file or directory
now what should I do?
mustangyhz
mustangyhz
china
Reply #9 - Nov 16th, 2010, 5:11pm
Thank you!
http://fixunix.com/mandriva/123550-problem-libraries.html
[jim@jb ~]$ locate libc.so.6
/lib/libc.so.6
/lib64/libc.so.6
[jim@jb ~]$ ls -l /lib/libc.so.6 /lib64/libc.so.6
lrwxrwxrwx 1 root root 11 May 9 12:37 /lib64/libc.so.6 -> libc-2.4.so
lrwxrwxrwx 1 root root 11 May 9 12:37 /lib/libc.so.6 -> libc-2.4.so
[jim@jb ~]$ ls -l /lib64/libc-2.4.so /lib/libc-2.4.so
-rwxr-xr-x 1 root root 1288656 Mar 7 2007 /lib64/libc-2.4.so
-rwxr-xr-x 1 root root 1232576 Mar 7 2007 /lib/libc-2.4.so
Check to see if you have the two libc-2.4.so libraries, and
if the symbolic links are correct.
You may need to link existing libc-2.4.so files to the needed
pathnames, using ln -s /existing/path/file /new/path/file
some one has solved this kind of problem like above.
I don't have the /usr/ius/tools/simvision/lib/libdcapi.so
I DON'T know what to do, so I just
copy /usr/ius/tools/simvision/lib/64bit/libdcapi.so   to    /usr/ius/tools/simvision/lib/libdcapi.so
and delete ls -l ./64bit/libdcapi.so
then [root@mml lib]# ln -s ../simvision/lib/libdcapi.so ./libdcapi.so
However, I don't solve my problem. I know it is wrong to copy /usr/ius/tools/simvision/lib/64bit/libdcapi.so   to    /usr/ius/tools/simvision/lib/libdcapi.so.
but, what should I do without  /usr/ius/tools/simvision/lib/libdcapi.so?
how can I use "ln -s /existing/path/file /new/path/file" without "/existing/path/file"?
help!!!
mustangyhz
mustangyhz
china
Reply #10 - Nov 16th, 2010, 6:25pm
Thank you!
I have solved my problem. I just copy the libdcapi.so from another tool lib to /usr/ius/tools/simvision/lib/ ,and then ln -s ../simvision/lib/libdcapi.so ./libdcapi.so
It works!
thank you verymuch!!!! Smiley
mustangyhz
