Jul 30th, 2024, 3:21pm
a input rail-to-rail opamp design (Read 3500 times)
Stone.M
China
Nov 15th, 2010, 4:32am
Hi guys,
I need to design a input rail-to-rail opamp, here is the spec:
1.Rail-to-Rail Input and Output;
2.Gain Bandwidth Product: 1.2MHz
3.7.5mV Typical VOS
4.Operates on 2.0 V to 5.5 V Supplies
5.Input Voltage Range: -0.1 V to +5.6 V with VCC = 5.5 V
6.Low Supply Current: 50μA
Can anyone pls give me some advice or some references? Thank you.
ontheverge
Re: a input rail-to-rail opamp design
Reply #1 - Nov 16th, 2010, 4:38am
technology?
raja.cedt
Reply #2 - Nov 16th, 2010, 5:14am
hi,
you have huge supply man, so start with folded cascode with  nmos and pmos input stages and proceed, if you need constant gm across full Input common mode range then go for complicated circuits. You can simple circuit for the specs in razaavi it self.
Thanks.
Reply #3 - Nov 22nd, 2010, 2:15pm
How about starting with a little academic research first?
No offense, but you need to open both textbooks and IEEE JSSC papers, rather than just throwing it at a forum and letting someone else do the work.
mowiehowie
Reply #4 - Dec 13th, 2010, 8:54am
theres a technique called "rail-to-rail input stage with complementary differential pairs". check it out.
