Jul 30th, 2024, 1:15pm
Auto zero comparator and process variation (Read 5978 times)
kanu
Dec 14th, 2010, 10:49am
Hi All,
We have designed an auto zero comparator for our project. I understand that the main purpose of auto zero comparator is to cancel small offset voltage. We are concerned about process variation too in our project. So I have a question regarding that. Is an auto zero comparator process variation sensitive ?
Kanu
AnalogDE
Re: Auto zero comparator and process variation
Reply #1 - Dec 14th, 2010, 11:08am
If designed properly you can make the design process insensitive.
kanu
Reply #2 - Dec 14th, 2010, 12:14pm
Hi AnalogDE,
Thanks for your reply. I wanted to confirm one more thing. It becomes insensitive to process variation...as the voltage on the capacitor is the voltage difference obtained due to process variation and is fed back from the output during cancellation phase ? Is this what you mean by a careful design.. ie, to sense the voltage at capacitor ?
Kanu
Lex
Eindhoven, Holland
Reply #3 - Dec 14th, 2010, 11:55pm
AnalogDE wrote on Dec 14th, 2010, 11:08am:
Are you sure? Leakage is PVT dependent, and so is charge injection and clk feedthrough.
AnalogDE
Reply #4 - Dec 15th, 2010, 10:17am
You cannot completely remove process sensitivity, but you can make those error sources "small enough" with proper design.
kanu
Reply #5 - Dec 16th, 2010, 8:12am
I have one more question. To make the offset very small what parameters do I need to consider ? Do I need to make the open loop gain high ?
Kanu
AnalogDE
Reply #6 - Dec 16th, 2010, 11:40am
If you are cancelling at the input (input offset sampling or IOS scheme) then you need high enough gain so you are not affected by gain error.  You also need closed loop stability.
If you are cancelling at the output (output offset sampling or OOS scheme) you'll need a low gain amp so when it's sampling its offset it doesn't rail out.  The amp operates in open loop during sampling, so no worries about closed loop stability.
Look up Razavi's book "Principles of Data Conversion System Design" for a good introductory discussion of the above schemes.
