Jul 17th, 2024, 3:35pm
Figure of merit for wideband low noise amplifier (Read 2483 times)
saam
india
Nov 23rd, 2010, 9:17pm
Hello
     Can anyone give the formula for the Figure of merit(FOM) for wideband low noise amplifier for wimax applications.
ThankU
saam
carlgrace
Berkeley, CA
Re: Figure of merit for wideband low noise amplifier
Reply #1 - Dec 1st, 2010, 4:03pm
There are many figures of merit available.  What performance metric are you interested in?  NF?  IIP3?  Gain?
aaron_do
Reply #2 - Dec 1st, 2010, 5:52pm
are you talking about one FOM to try and summarize the total performance of the LNA? If so, there is no perfect FOM. However, I have seen some very bad FOMs around. So as a suggestion, when you are deciding your FOM, it should be based on real tradeoffs in the circuit design. It doesn't make sense for you FOM to have something like VoltageGain(dB)/PowerConsumption(mW) because voltage gain in dB is not proportional to power consumption in mW.
cheers,
Aaron
