Jun 30th, 2025, 7:08pm
Question about Offset-Simulation of comparators (Read 6280 times)
mate
Nov 23rd, 2010, 11:45pm
i designed a latched comparator and performed a simulation like the one described in the paper 'A Methology for the Offset-simulation of comparators' http://www.designers-guide.org/Analysis/comparator.pdf from this website.
No I have some questions:
1. During the post-analysis in Matlab (code is at the bottom of this post) one defines
% select values within -2.5 .. 2.5 sigma
i=find(v>-2.5 & v < 2.5)
Why choose sigma = 2.5? At the end one defines
sigma = 1/p(1)
This should be the sigma_offset. This value changes if I use another value than 2.5 within the find function. I'm now not sure why he took 2.5 sigma.
2. My result gives me a mu of 30mV and a sigma of 30mV (when calculated like described). Is this interpretation correct:
My threshold is now: threshold_ideal+mu, but how do i interpret this sigma?
3. Does anyone know any material/website about how get sigma and mu from the polynomial coefficients?
Thanks for your help!
complete code:
% it is assumed that the simulation results are provided
% in the matrix "ydata" and the array "xdata"
% (1) ni/N, Figure 2
y = sum(ydata)/length(ydata);
plot(xdata, y)
% (2) inverse erf for rising slope only
% y(1:21) is this case contains the data
% for the rising slope
v = sqrt(2)∗erfinv(y(1:21)∗2−1);
% select values within −2.5 ... 2.5 sigma
i=find(v>−2.5 & v<2.5)
% fit line through selected values
% Figure 5
[p,s]=polyfit(xdata(i), v(i), 1);
plot(xdata(i), v(i), xdata(i), polyval(p,x(i)))
% (4) compute mu and sigma
sigma = 1/p(1);
mu = −p(2)/p(1);
mate
Re: Question about Offset-Simulation of comparators
Reply #1 - Nov 24th, 2010, 1:57am
i just want to add some of my results.
i have used
i = find(v>-3 & v<3)
the results are: μ: 2.5m σ: 25m
Is that σ value (25m) now my 3σ already or do i have to multiply that one with 3 to get 3σ (which would be 75m) Huh
« Last Edit: Nov 25th, 2010, 12:07am by mate »
AnalogDE
Reply #2 - Dec 18th, 2010, 8:38am
25mV is your one-sigma offset.  You multiply by 3 to get your 3sigma or you can also read it off the graph.  Mu is your systematic offset.
