DoYouLinux
It may sound strange in the topic. I am trying to run a simulation in ADS. There are two parts in this simulation. One part is to calculate parameters A1, A2 and A3 using MeaEqns. The other part is to use the obtained value of A1, A2 and A3 to fit parameters to a lumped model using Optimization.
Since Part 1 and Part 2 are in the same schematic, when A1, A2 and A3 are being calculated in Part 1, Part 2 is being evaluated at the same time. So, Part 2 is now using values of A1, A2 and A3 which are not final values because the calculation of both part are running simultaneously.
What I would is that:
First, Part 2 is disabled and Part 1 is enabled. Part 1 will then finish its calculation first, so that the final values of A1, A2 and A3 will be obtained.
Second, Part 1 is disabled and Part 2 is enabled. Now, Part 2 is using the final values of A1, A2 and A3 in the parameters fitting process.
---> How could I separate the calculation of Part 1 and Part 2 in sequence like this in ADS ??
Please suggest :-[
DYL
