Jul 18th, 2024, 5:27am
2-port (floating) impedance measurement in ADS (Read 3429 times)
DoYouLinux
Dec 02nd, 2010, 2:32am
I am wondering about a simple thing. In ADS, I have a lumped network consisting of a series branch (L and R) and a shunt branch (C and R), as shown in the attached figure. If I want to measure the impedance between both terminals of this lumped network, how should I proceed ? Clearly, I cannot ground the terminal at the shunt branch because this will eliminate the shunt branch.
Is there any building block in ADS that allows me to get a 2-terminal impedance like this network ? I need to extract this impedance to be used in a MeaEqn.
It seems that "Zin" block is not for floating impedance like this one, it should be for measuring impedance of a grounded network.
I should figure out how to do, but it seems not clear to me now.
Please suggest  :)
DYL
RFICDUDE
Re: 2-port (floating) impedance measurement in ADS
Reply #1 - Dec 2nd, 2010, 3:53pm
ADS has convenient measurement functions to convert S-parameters to other parameters such as Z or Y parameters.
A measurement equation will let you set some variable using the function
Z=stoz(S) I think is correct then you can break out Z11 and Z22 in the dataset and look at the real and imaginary parts.
I used to use this all the time for looking at EM simulation results for spiral inductor modeling.
