Jul 18th, 2024, 7:31am
EVM value in Cadence SpectreRF envelop analysis (Read 3903 times)
Mehran
Dec 04th, 2010, 10:09pm
Hi All,
     I am simulating a QPSK transmitter using envelop analysis in cadence. when I plot the EVM, I can see the constellation and the EVM error percentage on the wave scan. But I can't have that percentage error as a scalar value. Is there any way that I can obtain the calculated percentage error as a scalar value? I would like to change some parameter later and plot the EVM error percentage based on the swept value.
Thanks in advance,
-Mehran
View Profile mehranizad   IP Logged
Mehran
Re: EVM value in Cadence SpectreRF envelop analysis
Reply #1 - Dec 5th, 2010, 2:10am
     I know EVM is a scalar value. Maybe I couldn't make myself clear. When I use direct plot in analog design environment (Cadence Spectre-RF after envelop analysis), just like the post you refer me to it, I can see the constellation. The EVM value and number of the symbols are written on the constellation graph as a label.  I would like to know if there is any way I can get the calculated EVM and number of the symbols as a scalar value returned to the calculator and not a label on the graph? Is there any calculator function or OCEAN function that can do it ?(other than evmQpsk in calculator because its the same thing at direct plot)
Mehran
Reply #2 - Dec 5th, 2010, 2:16am
Hi Panchoo,
http://www.designers-guide.org/Forum/YaBB.pl?num=1260978648
you had this problem before. This was your question:
is there any method to get EVM value and Numbers of Symbol as string or numeric data from results of evmQpsk() ?
did you solve it?
