Sep 19th, 2026, 10:48pm
Error message simulating an AMS code using (Mentor) ICstudio Design Architect-IC (Read 2425 times)
Shady Adly
Egypt
Nov 27th, 2010, 1:02pm
I am new to both Verilog AMS and Mentor tools, but I need it for my graduation project.
I use Mentor tools, the simulator is ICstudio (Design Architect-IC v2008.2_1.1)
I wrote this simple code to make sure the design flow is working.
`include "disciplines.h"
module AMS_Verilog_AMS (in,out);
electrical in,out;
input in;
output out;
analog begin
V(out) <+ 3 * V(in);
After compiling the code I got no errors, then I created a new symbol, but after I checked the 'check HDL' tab I found this error message
//  Starting HDL compiler ... please wait
** Warning: (vsim-14) Failed to open "/tools/mentor/Projects/tester3.proj/mgc/.hdl_lib_a2008.2_p64/ADMS/modelsim.ini"
specified by the MODELSIM environment variable. Using "modelsim.ini" instead.
No such file or directory. (errno = ENOENT)
Compiling file: /tools/mentor/Projects/tester3.proj/Graduation_Project.lib/default.group/hdl.vie
ws/src/AMS.va
Compiling Module AMS_Verilog_AMS
______________________________________________
//  Starting HDL registration ... please wait
Error: An unexpected exit code(5) was returned from model registration
And now I can't put my block inside the design architect schematic!!
Any help would be really appreciated,
Shady Adly
View Profile Shady Adly shady.adly   IP Logged
