Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Feb 11
th
, 2026, 10:33pm
Home
Help
Search
Login
Register
PM to admin
Design Languages
VHDL-AMS
› read signal from type "1e-5" with VHDL
Previous topic
Next topic
read signal from type "1e-5" with VHDL (Read 2904 times)
jerome_ams
Dec 01
st
, 2010, 6:12am
I need to read some stimuli files which were initially created for spectre models (vpwlf).
The format "1e-5" is read by spectre but how to read it using VHDL? Read it as a string and then convert it to a real or time would be an alternative, but I m looking for something else, something more straight forward...
Any ideas?
Thx,
Jerome
IP Logged
carlgrace
Berkeley, CA
Re: read signal from type "1e-5" with VHDL
Reply #1 -
Dec 1
st
, 2010, 4:12pm
Hi Jerome,
Exponential notation is allowed for real numbers in VHDL. There shouldn't be any need to read the values in as strings and convert to reals. Read them in directly as reals and it should work fine.
Carl
IP Logged
jerome_ams
Reply #2 -
Dec 2
nd
, 2010, 1:34am
Hi carl,
You are right, 1.0e-5 for instance would be read fine.
But not 1e-5, which is neither a real, nor an integer... I really have to deal with such numbers, like 1e-5, 1e3, ...
IP Logged
jerome_ams
Reply #3 -
Dec 10
th
, 2010, 3:16am
Actually, I could wrap my VHDL code inside a VerilogAMS description...
Does anyone see a possibility to handle a value like 1e-5 in Verilog? (a possibility that VHDL would not have provided)
IP Logged
Reply #4 -
Jan 3
rd
, 2011, 12:09am
Can you give an example of some syntax that does not work (in VHDL and Verilog) as I'm struggling to understand what the actual problem is. I can't see why there should be an issue with floating point numbers in exponential syntax in either language.
IP Logged
jerome_ams
Reply #5 -
Jan 19
th
, 2011, 6:59am
The problem has been solved. Actually the way the stimulus generator is written induced the problem...
A value written from a stimulus file is splited in an integer and decimal parts, which leads to problems if the target value did not have a decimal part.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
»» VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2026
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
