Sep 15th, 2026, 4:24pm
read signal from type "1e-5" with VHDL (Read 3222 times)
jerome_ams
Dec 01st, 2010, 6:12am
I need to read some stimuli files which were initially created for spectre models (vpwlf).
The format "1e-5" is read by spectre but how to read it using VHDL? Read it as a string and then convert it to a real or time would be an alternative, but I m looking for something else, something more straight forward...
Any ideas?
Thx,
Jerome
carlgrace
Berkeley, CA
Re: read signal from type "1e-5" with VHDL
Reply #1 - Dec 1st, 2010, 4:12pm
Hi Jerome,
Exponential notation is allowed for real numbers in VHDL.  There shouldn't be any need to read the values in as strings and convert to reals.  Read them in directly as reals and it should work fine.
Carl
jerome_ams
Reply #2 - Dec 2nd, 2010, 1:34am
Hi carl,
You are right, 1.0e-5 for instance would be read fine.
But not 1e-5, which is neither a real, nor an integer... I really have to deal with such numbers, like 1e-5,  1e3, ...
jerome_ams
Reply #3 - Dec 10th, 2010, 3:16am
Actually, I could wrap my VHDL code inside a VerilogAMS description...
Does anyone see a possibility to handle a value like 1e-5 in Verilog? (a possibility that VHDL would not have provided)
Reply #4 - Jan 3rd, 2011, 12:09am
Can you give an example of some syntax that does not work (in VHDL and Verilog) as I'm struggling to understand what the actual problem is. I can't see why there should be an issue with floating point numbers in exponential syntax in either language.
jerome_ams
Reply #5 - Jan 19th, 2011, 6:59am
The problem has been solved. Actually the way the stimulus generator is written induced the problem...
A value written from a stimulus file is splited in an integer and decimal parts, which leads to problems if the target value did not have a decimal part.
