Hi there,
I've developed a code for a register which takes the values present at its two inputs named "input_1" and "input_2" when the value of the input "flanco_subida" is '1' and shows at the output the values taken from these two inputs until a new '1' appears at "flanco_subida".
The code I've written is shown below
Code:LIBRARY IEEE;
USE ieee.std_logic_1164.all;
ENTITY SampleHolder IS
PORT (input_2, flanco_bajada, clk, reset: IN std_logic;
input_1: IN std_logic_vector(3 downto 0);
output_1: OUT std_logic_vector(3 downto 0);
output_2: OUT std_logic
END SampleHolder;
ARCHITECTURE SampleHolderArch OF SampleHolder IS
--Declaracion de estados
TYPE Estado IS (EInicio, EDetectado, EMantenerSalida);
--Seņales auxiliares para la codificacion del estado actual y el estado siguiente
SIGNAL tEstadoActual, tEstadoSiguiente: Estado;
SIGNAL aux_1: std_logic_vector(3 downto 0);
BEGIN
--Proceso dedicado a la logica de estado
LOGICA_ESTADO: PROCESS (tEstadoActual, flanco_bajada)
BEGIN
CASE (tEstadoActual) IS
WHEN EInicio =>
IF (flanco_bajada = '1') THEN
tEstadoSiguiente <= EDetectado;
ELSE
tEstadoSiguiente <= EInicio;
END IF;
WHEN EDetectado =>
tEstadoSiguiente <= EMantenerSalida;
WHEN EMantenerSalida =>
ELSE
END IF;
END CASE;
END PROCESS LOGICA_ESTADO;
--Proceso dedicado a la memoria de estado
MEM_ESTADO: PROCESS (clk, reset)
BEGIN
IF (clk'EVENT and clk = '1') THEN
IF (reset = '1') THEN
tEstadoActual <= EInicio;
ELSE
tEstadoActual <= tEstadoSiguiente;
END IF;
END IF;
END PROCESS MEM_ESTADO;
--Proceso dedicado a la logica de salida
output_1 <= input_1 WHEN tEstadoActual = EDetectado ELSE "0000";
--"0000" WHEN tEstadoActual = EInicio;
output_2 <= input_2 WHEN tEstadoActual = EDetectado ELSE
'0' WHEN tEstadoActual = EInicio;
END SampleHolderArch;
The problem that I have is that, when I compile my code with Quartus II, I get a message saying "Warning: Timing Analysis is analyzing one or more combinational loops as latches" / "Warning: Node "SampleHolder|output2|combout" is a latch".
If I change the line
for
'0';
the warning message disappears, but, as expected, the behaviour of the system is not as desired.
Help from anyone?
Thanks so much
