carlgrace wrote on Dec 3rd, 2010, 8:30am:Matteo,
Putting fill blocking layer over your M7 signal lines is a very good idea! You may have some troubles meeting minimum density rules though if these signal lines are big and are used over a large part of the chip.
Is M6 a thick metal in your process? If so and you are having problems meeting density you can consider only block the thick metals underneath your wires. It is usually no trouble meeting global density requirements on the thick metals because you are using them for power routing and such. It may be an issue on local density depending on the window size in your process.
I say this because the thin metals really don't make too much of a difference, particularly if you have a single-ended circuit. I built a 6 GHz LNA about 2 years ago in 65nm CMOS and I was forced to allow fill underneath signal wires and capacitors. What, I did was to build my own layout cell that had the minimum allowable metal density, then I tiled it under my MIMCAPS and thick metal routes. I found that the autofill routine put down more metal than necessary and also caused a little bit of mismatch between differential capacitors. My LNA came back from fab working great.
Good luck,
Carl
Thanks for your suggestions Carl!
M6 is thick in this process but I'm using it to take high freq signal around in the chip, not only for power routing.
Your idea to build your own cell that meets the min density rules is good. I think I'll send it back to the foundry with the blocking layers, see if they manage to meet the density rules and if not - hope doesnt happen, I'll do as you did
![Smiley Smiley](https://designers-guide.org/forum/Templates/Forum/default/smiley.gif)
Have a good day
Matteo
