Why are you using such an old version of spectre? spectre in the IC5141 has not been updated for some considerable time. At the end of 2004 (soon after IC5141 came out), spectre was split off into a separate stream, MMSIM. Since then there have been MMSIM60, MMSIM61, MMSIM62, MMSIM70, MMSIM71, MMSIM72 and MMSIM101. That's 7 major releases, so you are using a really old version of spectre, lacking in a lot of improvements and enhancements. There's no reason why you can't use a recent MMSIM version with IC5141 - that's really the recommendation.
That said, I don't think dynamic parameters is the solution in this case, as Ken said - controlling the accuracy of the simulator would be a better option. I just wanted to ensure you're actually taking advantage of 6 more years of simulator evolution and improvement!
