Jul 18th, 2024, 11:27am
Device Noise Parameter Description (Read 2289 times)
Upemba
Dec 08th, 2010, 9:06am
I run a pnoise SpectreRF simulation and I am not able to identify each noise contribution parameter reported.  For instance: id stands for channel thermal noise, fn for flicker noise of MOS transistors.  I am having additional parameters that I am not able to identify.  Can someone help me to describe each noise paramter.  Below is the list:
1.  MOS transistors: what is rs and rd?
2.  BJT transistors: what is ic, ib, rb
3.  Resistors: what is rs? I thought rn was thermal noise of resistors.
Thank in advance for your answers
Re: Device Noise Parameter Description
Reply #1 - Dec 9th, 2010, 6:45pm
Upemba,
  Here are my guesses:
1) Thermal noise of the source and drain resistance: rs, rd
2) base and collector current shot noise: ib, ic
   Thermal noise of the base resistance: rb
   Note: there are additional terms for rc and re but their effect is
            usually small
3) Noise for the source resistance, the noise of the port
Upemba
Reply #2 - Dec 10th, 2010, 3:38pm
Thank you
