Jul 18th, 2024, 1:27pm
ams+1st order sigma delta modulator+ no output (Read 156 times)
mustangyhz
china
Dec 08th, 2010, 6:37pm
I want to simulate a fractional-N PLL. So, I designed a 1st order sigma delta modultor to contol a 2/3 divider. I simulate this modulator in IUS. it works! But, I failed when I simulated it with AMS after making it a cellview.
code:
`timescale 10ps / 1ps
module sdm1(clk, rst, v_out);
input clk, rst;
//input [28:0] k_in;
output  v_out;
reg  v_out;
reg [28:0] a1;
wire [28:0] s1,q1;
wire  c1;
//assign s1 = 29'b00100110011010011010110101000 + a1;
assign s1 = a1;
assign c1 = {s1[28]};
assign q1={s1[27:0] };
always@(posedge clk or posedge rst)
begin
     if(rst) a1<=29'h0;
     else a1<=q1;
begin
     if(rst)
     begin
           v_out<=1'b01;
else
     begin
           v_out<=c1;
why?
anybody can help me?
mustangyhz
View Profile mustangyhz 3241568   IP Logged
mustangyhz
china
Re: ams+1st order sigma delta modulator+ no output
Reply #1 - Dec 8th, 2010, 6:38pm
the correct output in IUS: [img][/img]
mustangyhz
mustangyhz
china
Reply #2 - Dec 8th, 2010, 6:39pm
The test file in ius:
`timescale 1ns / 1ps
module test;
reg clk;
reg rst;
//reg [28:0] k_dth;
reg [31:0] bout_sum, clk_sum, averange;
wire bout;
modulator M1(clk, rst, bout);
always #42 clk = ~clk;
initial
begin
   bout_sum = 32'b0;
   clk_sum = 32'b0;
   averange = 32'b0;
   clk = 1'b0;
  // k_dth = 29'b0;
   rst = 1'b1;
 //  #98 k_dth = 29'b00100110011010011010110101000;
//4cd35a8
   #0.01 rst=1'b0;
   #100000 $stop;
begin
if (rst)
 begin
 bout_sum = 32'b0;
 clk_sum = 32'b0;
 averange = 32'b0;
else
 begin
           bout_sum = bout_sum + bout ;
           clk_sum = clk_sum + 1;
           averange = {bout_sum,28'b0}/clk_sum;
mustangyhz
mustangyhz
china
Reply #3 - Dec 8th, 2010, 6:41pm
the library in cadence
mustangyhz
mustangyhz
china
Reply #4 - Dec 8th, 2010, 11:33pm
I have solved the problem
ConnRules
/usr/ius/tools/affirma_ams/etc/connect_lib/connectLib/ConnRules_18V_full_fast/co
nnect
Vsupply=1.8V
mustangyhz
