Jul 29th, 2024, 7:18am
OPAMP input resistance (Read 3014 times)
extremis
Dec 29th, 2010, 5:15am
Could an OPAMP have different input resistances for +/- inputs? Would that be a problem?
rfmagic
Re: OPAMP input resistance
Reply #1 - Dec 30th, 2010, 1:17am
In open loop condition the +/- input of the opamp are typically identical. the probelm is in closed loop condition. this is the main reason for using an instrumentation amplifier
take a look at the attached document
nus_lin
Reply #2 - Jan 15th, 2011, 7:06pm
for bipolar opamp, you will see input resistance, but for cmos opamp, ideally, the resistance approaches infinity. in reality, due to the esd, cmos opamp also has a resistor in the range of 100M ohm.
raja.cedt
Reply #3 - Jan 16th, 2011, 5:28am
due to leakge there may be chance of having differential resisatnce in cmos.
Thanks.
HdrChopper
Reply #4 - Jan 17th, 2011, 4:43pm
It is true that in closed loop the input resistance might be different in the + and - inputs, but only for single ended configurations.
For fully balanced opamps both inputs have the same circuit connected to them, and due to the balanced nature of the circuit, the input resistance for both of them will be ideally identical, the same way they are under open loop conditions.
Concerning MOS inputs, the input resistance will be almost infinite but only at DC. At higher frequencies the unbalance will be noticeable again only for SE topologies, while for FB configurations they should be identical.
Best
Tosei
Keep it simple
