Jul 29th, 2024, 1:31pm
Pages: 1 2
Biquad types (Read 690 times)
rfmagic
Biquad types
Dec 30th, 2010, 1:19pm
I am designing a 5th order Butterworth filter using casceded biquads. I have seen many topologies to implement a biquad but I am not sure I got the main advantages of each type.
I appreciate is someone could tell me the main advantages and disadvantages of the following biquad types:
1. Sallen_Key
2. MFB
3. Tow-Thomas
buddypoor
Bremen, Germany
Re: Biquad types
Reply #1 - Dec 31st, 2010, 1:49am
rfmagic wrote on Dec 30th, 2010, 1:19pm:
1. Sallen_Key
2. MFB
3. Tow-Thomas
At first, I wouln't call S+K and MFB a "Biquad" since both cannot create a biquadratic transfer function - but that's not too important.
In particular:
* S+K is rather sensitive to parts tolerances, but less sensitive to opamps GBW.
* Just the opposite is true for MFB
* The TT-biquad also is not suited for rather high frequencies (because of sensitivity to the GBW). More than that, it uses more than one opamp (as both other alternatives, S+K, MFB).
*One additional hint: The cascade approach (several stages in series) is not the best from the sensitivity point of view. What about active realization of a passive ladder structure (FDNR technique)?
rfidea
Europe
Re: Biquad types
Reply #2 - Dec 31st, 2010, 1:52am
Hi!
One difference between Sallen Key and MFB is that you can easily build a fully differential filter with the MFB, which is tricky with the Sallen Key.
Tow-Thomas can give you a bandpass filter if you need it.
Have you looked into a leapfrog architecture? It is a robust architechture and I believe that you get better SNR performance per current consumption. But it requires some theory to calculate the RC values.
rfmagic
Re: Biquad types
Reply #3 - Dec 31st, 2010, 4:15am
Thanks for your reply...
Buddypoor,
is it possible to design a filter with such a minimal sensitivity to parts and GBW so that it will eliminate the need for calibration?. the tolerance for CMOS 0.18u technology is pretty large (+/- 15%).
I saw some designs that actually use TT stages in cascade  for WLAN zero IF frequencies (<20MHz BW) can you think of a possible advantage of the TT over other configurations even though it uses 2 opamps?.
Which configuration has the best noise performance?
Thanks in advance
I
rfmagic
Re: Biquad types
Reply #4 - Dec 31st, 2010, 4:59am
ssahl,
I am not familiar with the the leapfrog implementation but I will look into that as it has better noise performance according to your reply.
At first I wanted to used the cascaded Biquads architecture as it is very simple implement.
rfidea
Europe
Re: Biquad types
Reply #5 - Jan 2nd, 2011, 7:06am
rfmagic wrote on Dec 31st, 2010, 4:59am:
ssahl,
Yeah, the biquads are much simpler to understand. But for high orders you get vary high Q-value for some of the biquads and you need low-resistors to get the noise performance. I think it is worth the extra theoretical effort of the leapfrog. I found some simple presentation how to make it work.
http://amesp02.tamu.edu/~sanchez/458-Leapfrog.PDF
/ssahl
rfmagic
Re: Biquad types
Reply #6 - Jan 2nd, 2011, 10:12am
Thanks for the presentation ssahl, i
I am not sure I that I get your point, in order to get good noise performance I would expect to have high Q circuit so that the resistive components will be low, right? but you say just the opposite...
If my argument is correct then it will be better to use a cascaded biquads.
rfidea
Europe
Re: Biquad types
Reply #7 - Jan 2nd, 2011, 12:46pm
rfmagic wrote on Jan 2nd, 2011, 10:12am:
what I meant my high Q circuits is the Q-value of the pole that the active filter is implementing, not the Q value of the components itself.
For the biquad implementation all poles needs to be placed in a specific biquad. Placing the ones with high Q early will make the filter to peak internally. This generates large voltage swing. To handle that you probably need to lower the gain to that point. Keeping the SNR you need to lower the resistor values and increasing the capacitor values, which cost you current in the opamps.
If you try out the leapfrog structure it looks like there is less peaking internally in the filter. (I have no theoretical proof for this but it is my experiance.) This lower peaking means that you can keep a larger signal swing in the filter and therefor keeping the SNR high without going for low resistor values.
I hope this explaination makes sense.
/ssahl
buddypoor
Bremen, Germany
Re: Biquad types
Reply #8 - Jan 3rd, 2011, 1:48am
Yes, I agree with ssahl concerning trade-off between leapfrog and cascade design.
One additional recommendation: Why not use - at least to gather some information about circuit alternatives - some filter design programs?
There are several different design programs available for free via download.
I tend to remember that there is even a program containing the leapfrog topology (filter_solutions).
rfmagic
Re: Biquad types
Reply #9 - Jan 3rd, 2011, 4:58am
buddypoor,
That's a very good idea, following your input and ssahl inputs, I started to wonder how to compare the different alternatives quickly, and without making this project to complicated. I am working with ADS and the "Filter Design Guide" only synthesises lumped elements ladder networks so I suppose that this is not the right tool as it still leaves me too much work to transform the passive ladder into an active one.
It will be very nice to use a program that can generate diffrent Active filter architectures in order to compare their performance. Is the program that you recommend (filter_solutions) can do that?
buddypoor
Bremen, Germany
Re: Biquad types
Reply #10 - Jan 3rd, 2011, 7:15am
Here are some useful links for active filters:
*www.filter-solutions.com (filter_free)
*www.microchip.com (Filterlab)
*www.ti.com (FilterPro)
*www.schematica.com (FilWizPro)
All have working demo versions for free
rfidea
Europe
Re: Biquad types
Reply #11 - Jan 3rd, 2011, 7:27am
buddypoor wrote on Jan 3rd, 2011, 7:15am:
I have found a simple program from Linear by which you can get the poles and zeros from a filter. I have found it useful.
http://www.linear.com/designtools/software/filtercad.jsp
rfmagic
Re: Biquad types
Reply #12 - Jan 3rd, 2011, 7:36am
Thanks guys,
I will take a look at the links and update you on the results
buddypoor
Bremen, Germany
Re: Biquad types
Reply #13 - Jan 3rd, 2011, 9:15am
Hi ssahl, I know the program from LTC - and, indeed, it is very useful to find the pole parameter for different approximations.
However, it gives parts values only for the design of filter modules from LTC. Thus, it cannot help by designing other structures.
rfidea
Europe
Re: Biquad types
Reply #14 - Jan 3rd, 2011, 11:55am
Hi Buddy!
Yes, the only use I have of it is the poles and zeros. It's lika a filter table. Thanks for the tips of the other softwares, I will have a look at them next time I run into a filter problem.
Cheers
Pages: 1 2
