raja.cedt wrote on Mar 16th, 2013, 11:05am:@frank: Thanks for your posts on stability, they were really help full. Can you please tell me is there any way to plot nyquist plot in cadence? i am always plotting one half circle corresponding to +ve frequency and rest i am adjusting in Matlab.
I just plot half of the curve (like Milind did) and imagine the other half, which is simply mirrored along the real axis.
raja.cedt wrote on Mar 16th, 2013, 11:05am:@milind: Please find the loop gain expression for frank example. You have to consider +1 encirclements...here 0 encirclements, we know already no open loop RHP hence system is stable. How did you get RHP??
I think that Milind is referring to the cases where gain>1m. Here we have a counterclockwise encirclement of the critical point +1. This is due to the fact that the loop gain (but not the closed-loop gain) has a right-half-plane pole, so that the circuit is open-loop unstable.
However, when the loop is closed, the circuit is stable and the right-half-plane pole of the loop gain becomes a right-half-plane zero of the closed-loop gain. This situation is described in the following quote from
http://en.wikipedia.org/wiki/Nyquist_stability_criterion (where the critical point is -1):
Quote:If the system is originally open-loop unstable, feedback is necessary to stabilize the system. Right-half-plane (RHP) poles represent that instability. For closed-loop stability of a system, the number of closed-loop roots in the right half of the s-plane must be zero. Hence, the number of counter-clockwise encirclements about -1+j0 must be equal to the number of open-loop poles in the RHP.
