Jul 29th, 2024, 1:20pm
does NPN bjt integratable with EEPROM process? (Read 1733 times)
nus_lin
Jan 12th, 2011, 4:08am
hi guys, the beta value for PNP lateral bjt is 3 for typical. if i want to make very accurate bandgap reference, this is far too small.
vertical NPN bjt made out of N+ bury layer is much better, and is better for BGR.
An accurate BGR needs to trim very accurately, so i need EEPROM option to store the trim bits.
however, for MPW runs available (SMIC, for instance), the process options providing NPN bjt and EEPROM are different, for instance, smic18mix and smic18ee.
my question is, is it possible to do so using another process or modify the current mixed signal process?
nus_lin
Re: does NPN bjt integratable with EEPROM process?
Reply #1 - Jan 13th, 2011, 11:17pm
ok, i figured out a way to make nice circuit without NPN bjt.
