Hello evryone,
I have two queries which I am listing below:
1.
I am trying to model a verilog A model of continuous time bi directional shift registers.
Based on the input signal and clock the output can be either incremented or decremented by one (normal bi directional shift register operation).
I have clock and input signal as my input and N (variable = 8 to 512) output ports. All in continuous time. There is no sampling done anywhere. The clock mentioned above and in the code is another signal which is being used as clock to perform the operation (kind of asynchronous operations).
Code I have written is as shown below:
@ (initial_step)begin
for (i=0; i<256;i=i+1)
begin
result[i]=0; // temp location to store result initialize to zero
end // initial
@(cross(V(clk)-clkThresh, -1)) begin
sampleIn = V(vIn); // vIn is the input voltage
for (i =0; i<N; i = i+1)
begin
if (sampleIn >=0.5)
begin
result[0] = 0; // first bit set to zero
result[i+1] = result[i]; // rest all shifted right
else if (sampleIn < 0.5)
begin
result[i] = result[i+1]; // all bits shifted to left
result[N-1] = 0; // last one set to zero
// final assignment of the output signal
V(srOut[i]) <+ transition(result[i], td, tr, tf);
end module
My problem is I am not able to model the N output ports in verilogA. Final assignment as highlighted in red is throwing parsing error.
'the index used to bits of analog signal vector srOut is constant, constant expression, genvar-constant expression. To avoid this problem, ensure that the index used to access the bits of analog signal is constant, constant expression, genvar-constant expression.'
Can someone please help me to resolve my problem.
Also I ll be glad to provide any information or to clarify any point if not clear above.
2.
In the variable ADC code at
http://www.designers-guide.org/VerilogAMS/functional-blocks/data-converter/conve... can some one please explain me the ussage of following statement:
localparam integer levels = 1<<`bits;
xyzLinkoping
