Jul 28th, 2024, 7:28pm
Pages: 1 2
Energy stored in capacitor (Read 522 times)
rfidea
Europe
Re: Energy stored in capacitor
Reply #15 - Feb 05th, 2011, 2:19pm
Your derivation is correct. It also match the energy "law" of a capacitor, E=0.5CV^2.
But you are saying that you get the same answer with the resistor. In earlier post you say you get CV^2, if the voltage is a ramp.
I think you have mixed up the energy provided from the supply when it applies a step voltage into the RC network. In that case the energi provided will be CV^2 and independed of R. You can not use this relationship with a ramp with zero transition time. Then you can not solve the i=C*dv/dt relationship of the capacitor and we are back where we started with the two capacitors.
Rakesh
Reply #16 - Feb 5th, 2011, 2:36pm
I think there is some misunderstanding.. Jus see this..
Voltage across battery will be iR +1/c integral(i dt). and that we need to integrate over time . So i think u il get loss term in resistor if we include it.
Answer should not change in watever way we do.
When u give a ramp the volage across the cap will not be derivative of ramp due to resistor. we need to solve some first order differential equation..
is this ok with you
Reply #17 - Feb 5th, 2011, 5:09pm
as for the original post - the energy remains the same - remember that 2 variables are changings - voltage and capacitance.
As for the Ideal voltage source and ideal capacitor - sure why not? Just need infinite current for a brief period of time.
BTW - if you can give me a true ideal voltage source, we can solve the worlds energy problems.
Rakesh
Reply #18 - Feb 5th, 2011, 5:17pm
Hi tats true...think of condition of charging cap with ideal voltage source..
Some how we migrated to this question.
Energy supplied by battery and energy stored in capacitor are the same.. We wont get any loss
Is it corect to say this...
rfidea
Europe
Reply #19 - Feb 6th, 2011, 1:45am
Rakesh wrote on Feb 5th, 2011, 2:36pm:
is this ok with you
The equations you are starting with is ok for me since you include the resistor. If you solving the differential system, please not forget that the voltage ramp is flatting out which influence the current.
You claiming that the answer will not change. I do not understand which answer will not change? And you can not say anything about the answer unless you have sokved the differential system and have an expression of i(t) and the integrate v(t)*i(t).
Rakesh
Reply #20 - Feb 6th, 2011, 10:47am
i = Vdd*C/(T)*(1-exp(-t/RC)).
This equation we need to integrate from 0 to infinity . keep in mind we need to consider the flattening of voltage at battery after t =T.
Is it correct way of  doing...
rfidea
Europe
Reply #21 - Feb 6th, 2011, 12:24pm
Yes, I got the same equation when trying to solve the ramp problem with a resistor. It is valid up to t=T. I did not proceed, I'm to lazy I guess Smiley
But you are on the right track. After t=T the voltage is constant and there is a new differential equation to solve, with the initial condition set by the first equation.
Rakesh
Reply #22 - Feb 6th, 2011, 12:47pm
May i know your name and the place wer u belong to... jus for fun  :D
Pages: 1 2
