Rakesh,
You are looking at the problem backwards. The latch does not go out of latch unless forced, for example, by shorting a switch across the inverters. You solve the problem by assuming that the two inverters are biased at their switching threshold, i.e., the level of the input and output the instant after that ever so helpful switch opens. In this case all the transistors are biased in saturation, both the inverters have gain, and the loop gain is large, >>1.
