Jul 28th, 2024, 5:24pm
Pages: 1 2
Energy stored in capacitor (Read 506 times)
Rakesh
Feb 04th, 2011, 1:28pm
Assume a System with two capacitors. one is charged to voltage V and other has voltage 0 on it. So the energy in the system is (0.5CV^2).
Now lets says i connect the two capacitors in parallel. So the voltage across them will be V/2. Energy in the system is  0.5*(0.5CV^2).
Question is where does the remaining energy go as i dont have any resistor in charging capacitor.
Secondly is it possible to charge a cap with ideal voltage source.
RobG
Bozeman, MT
Re: Energy stored in capacitor
Reply #1 - Feb 4th, 2011, 2:57pm
If you were to calculate the energy loss due to a finite switch resistance you would find that it is equal to (CV2)/4. Note that it is independent of the resistance value -- so the energy gets used up by the resistance even if it is zero (in the case of zero resistance you get an infinite charging current: ∞2*0 = (CV2)/4 in this case when you take the limit).
Or it gets converted to dark matter. I sometimes get those two mixed up Wink.
Rakesh
Reply #2 - Feb 4th, 2011, 7:03pm
I agree tat half of the energy is lost in resistor however small it is.
But if we dont have resistor how can we say that we have a loss. We get a infinete current for 0 time interval. Is it that capacitor will not get charged.
We can take the limit provided the limit exists. we have a discontinuity at the instant we turn on the switch. The node voltage is not known as the first capacitor will force it to be V and second zero at the same time.
I think like this..
Impulse  in time domain transforms to constant in freuency domain. And the energy will remain constant. The current will be quadrature in phase to the current . So the integral of voltage times current gives zero. integral(sin(x)cos(x)=0). So we dont lose any real power or we dont get real current to charge the capacitor.
rfidea
Europe
Reply #3 - Feb 5th, 2011, 1:15am
I do not understand where you get sin(x) and cos(x) from. The voltages and currents when re-charging the two capacitors will not be sin(x) or cos(x), exp(x) it will be if you have a resistors in-between.
I agree with the explaination from RobG. The energy loss in an assumed series resistor is independet of the value of it. It you take the limit r=>0 you will get the result. The problem can not be solved without a resistor. You can not mathematicly describe the current flowing from cap1 to cap2 without any resistor, the equation does not exist.
raja.cedt
Reply #4 - Feb 5th, 2011, 1:39am
hi rfid,
what rakesh intention (i guess) is when you charge cap without resistor current looks like impulse. So impulse Fourier transform is white.
Thanks.
rfidea
Europe
Reply #5 - Feb 5th, 2011, 5:28am
Yes, the current shape will look like a Dirac-pulse, it will be nil for all times except t=0 but the integral from -∞ to +∞ is finit and not zero. (Strange thing but that is the Dirac pulse)
Rakesh
Reply #6 - Feb 5th, 2011, 8:10am
ok Assume the condition like this.. u r charging a cap with ideal voltage source.
I can sat that voltage in the source is a unit step function. We will get dirac delta function in current which is difficult to handle.
So assume that voltage in the voltage source as a ramp with slope mt. it become step when m tends to infinity.
In this case if we find the energy supplied by the battery is 0.5CV^2 in the limit m tending to infinity.and not CV^2 which we will get wen we have resistor.
This tells that if we dont have any resistor we wont have any loss in charging a cap. However even if we have a small resistor we will lose half of the energy if we charge at one go.
Similarly is it possible to explain that two capacitor problem
Rakesh
Reply #7 - Feb 5th, 2011, 8:15am
at Rfidea.
Agreed current will be a dirac delta. I dont know tha magnitude of current.. it is undefined.
first of all its not possible to differentiate a discontinuos function so wat to talk of current.
So integral of that from -inf to inf is undefined and not zero.
my question is i dont have any lossy element in the system.. Then wer does the remaining power goes off. I agree half will get lost even if we have very very small value of resitor. the case here is no resistor..
rfidea
Europe
Reply #8 - Feb 5th, 2011, 8:39am
Hi Rakesh!
About the Dirac delta pulse. Yes, the value at t=0 is inifinity or not defined. But the integral is! That is the Dirac delta pulse, see also
http://en.wikipedia.org/wiki/Dirac_delta_function
This is more or less exactly what happens when you using r=>0. If you try to solve the electronic problem with two caps you will not be able to get expressions how the current and voltage looks like during the recharging, whithout putting in a resistor. (If you are a skilled math pro, I'm not, you maybe can use the Dirac delta function) This is like saying that the problem without a resistor is non-physical and the basic relationship of a capacitor, i=C*dv/dt, can not be solved for this problem.
Rakesh
Reply #9 - Feb 5th, 2011, 9:00am
Hi rf idea,
           Agreed integral od dirac delta is one..its given this is heuristic idea not proven though...
agreed its impractical to have a circuit with zero resistance. this ques is for understanding only...
jus consider this case charging cap from ideal voltage source..same prob exists..so change the supply voltage as a ramp and make the slope tending to infinity..
we will get energy supplied from battery is 0.5CV^2 and not CV^2 as we wil get if we aasume a resistor and making r tending tonfinity...
rfidea
Europe
Reply #10 - Feb 5th, 2011, 9:17am
Hi Rakesh!
Yes, the charging with a slope seems interesting. I do not have any explaination. You claim that the energy from the battery when a resistor is used is CV^2. I was trying to solve that problem with some differential equations. It seems to be a hard labor to get it the whole way... Have you done it or have you a simpler way to prove it?
Rakesh
Reply #11 - Feb 5th, 2011, 10:53am
Hi rfidea..
        i have derived it... i il post it after drafting it sooner...its really an interesting problem.. lets figure it out  :D
Rakesh
Reply #12 - Feb 5th, 2011, 12:45pm
      just see the derivation attached  for the problem ideal battery charging the capacitor.
rfidea
Europe
Reply #13 - Feb 5th, 2011, 1:42pm
Yes, that is without any resistor, I agree. But the math get a lot more complicated when you add the resistor.
Rakesh
Reply #14 - Feb 5th, 2011, 1:45pm
True agreed. Math gets complicated with resistor, but u il get the same answer. This is because once the capacitor is charged u il get current through the cap as zero.
Wat do you think of the derivation that without resistor energy supplied by battery is 0.5CV^2 or there is any flaw. Kiss
Pages: 1 2
