Pashtet
Belarus
Hello, friends. When we measure phase noise of VCO the output curve is in dBc/Hz. But if i want to find rms noise, for example, in 1KHz-1MHz range i get result in degrees or radians. So my question is the following - what are the mathematical relation between these values, i.e. how i can derive mathematically rms noise in degrees having phase noise curve in dBc/Hz?
