Dec 18th, 2025, 12:43am
z transform filter in ac (Read 7694 times)
roberto_d
Switzerland
Feb 22nd, 2011, 5:14am
I'm trying to implement some z transform filters in Verilog-A (to be simulated with Spectre).
I did a very simple sample and hold (transfer function =1 in z domain):
Quote:
`include "constants.vams"
`include "disciplines.vams"
module sh(MINUS, PLUS);
  inout MINUS;
 electrical MINUS;
 inout PLUS;
 electrical PLUS;
 analog begin
   V(MINUS)<+zi_nd(V(PLUS),{1},{1},2u,2n);
This work perfectly fine in the time domain, but shouldn't I also see the effect of s/h in ac analysis? In fact, what I see in ac is vout=vin
Roberto
August West
I'll get up and fly
away
Re: z transform filter in ac
Reply #1 - Feb 23rd, 2011, 1:01am
Yes, of course. However, if you carefully look at the log file you will probably find a warning that says that the z-filter is not implemented in AC analysis yet. That message has been there since 1994. I'm thinking this one is not a high priority for Cadence.
August
roberto_d
Switzerland
Reply #2 - Feb 23rd, 2011, 9:30am
I see... It would have been too nice...
But since 94 they made a BIG step forward, now they don't even show a warning in the log file!
Ok thanks, at least I can stop asking myself what I did wrong.
August West
I'll get up and fly
away
Reply #3 - Feb 24th, 2011, 11:30pm
If you don't see the warning message, then you might want to inquire with Cadence. After all, it has been a 16 years. Perhaps they did get around to fixing it, or at least trying to. After all, why would they take out the warning if they didn't try to fix it?
And, besides, if they did not fix it, they should at least be made aware from time to time that people care.
-August
