Jul 21st, 2024, 6:20pm
the linearity of the source follower (Read 9447 times)
yishuihan
The Netherlands
Feb 26th, 2011, 3:34am
Hi guys:
we know that for the NMOS source follower, when Vbs is not zero, the linearity is low because of the body effect.  it is not suggested using the source follower when the linearity is the main consideration.
however,  we also know that the body effect can be regards as a gmb conductance and behaves like an source degenerator. to some extent the linearity can be better.
who can tell me why there is this paradox?
thanks in advance.
View Profile yishuihan   IP Logged
Rakesh
Re: the linearity of the source follower
Reply #1 - Feb 26th, 2011, 4:36pm
For the Source follower you have negative feedback in the gm loop, So the swing vgs is small, However if you think of vbs swing is higher and hence the gmbs is not constant for all range of the voltage. Hence this will result in non linearity.
Correct me if i am wrong
Rakesh
yishuihan
The Netherlands
Reply #2 - Feb 27th, 2011, 2:54am
Hi Rakesh:
that's true there is a negative feedback loop via the degenerator (resistor or current source),  quick conclusion would be the larger loopgain, the better linearity.
i realize my confusion might be the working conditon of the transistor. if the AC signal is samll, body effect is not a severe issue. for the large signal, the source will not track the gate voltage any more due to the dependence of the Vth on the Vbs.
anyhow, for the small signal, when Vbs is none zero, the equivalent gmb is paralled with others, loopgain will decrease more or less, thus the lineariy.
Rakesh
Reply #3 - Feb 27th, 2011, 6:57am
Even for large signal if u have sufficient loop gain then i think source will track gate voltage.
Basically there are two paths from input to output. once is via gm and other via gmb. The path via gm has negative feedback and hence it is a linear path. However path via gmb is a open loop system and hence u ve a large swing . So u have non linearity.
The change in vth with signal is included by variation of gmb with signal
carlgrace
Berkeley, CA
Reply #4 - Mar 3rd, 2011, 3:50pm
yishuihan wrote on Feb 26th, 2011, 3:34am:
Hi guys:
thanks in advance.
There is no paradox.  Try simulating a source follower with a non-constant source degeneration resistor.  It would not improve linearity.  The gmb conductance is not constant across the output swing of the source follower.
« Last Edit: Mar 4th, 2011, 8:31am by carlgrace »
RobG
Bozeman, MT
Reply #5 - Mar 7th, 2011, 2:50pm
To give another viewpoint... Degeneration helps stabilize current mirrors so that a "large" variation in gate-source voltage causes a "small" change in current. By the same principle, a "small" current change in a degenerated fet will result in a "large" voltage change. This "large" voltage change is exactly what you don't want in a source follower!
As you know, the effect described above isn't the normal problem (it is the Vt dependence on bulk-source voltage); however, I hope it helps answer the question on why it doesn't help.
LazyDesigner
South Korea
Reply #6 - Mar 12th, 2014, 4:57pm
Hi Guys
What if we make Vbs=0 by using IPW(deep-nwell)?
View Profile sainiparvesh   IP Logged
raja.cedt
Reply #7 - Mar 13th, 2014, 4:08am
in that case there is no Question of body effect, hence it is irrelevant here. But with deep-nwell source will loaded with huge capacitance, may be limited frequency response, i guess this is the reason why people go for pmos source follower than deep-nweel case (even if their technology allows).
Raj.
