Apr 27th, 2024, 2:04pm
PLL phase noise simulatioon using spectreRF (Read 3755 times)
Dinesh Agarwal
Mar 02nd, 2011, 5:04pm
1.     I could simulate the phase noise of PFD+CP+LP using PSS and Pnoise simulation.
2.     In second case only PFD+Cp was included for same setup.
The result in both the cases are same. Is this right, i think there should some difference in twocases, as there is resistance thermal noise in LP
Pls comment
dinesh
Analog Design
View Profile dineshkumar_33 688078 din   IP Logged
rajkumar palwai
Sunnyvale, California
Re: PLL phase noise simulatioon using spectreRF
Reply #1 - Apr 10th, 2011, 3:42am
Hi Dinesh,
What is the freq range of your pss+pnoise simulation? If u are simulating at low freq, then your CP flicker noise can be so dominant that you are unable to see the filter resistor thermal noise contribution.
regards
rajkumar
