Jul 27th, 2024, 1:12pm
Interesting problem: Need block level model for microprocessor (Read 2025 times)
dtzihe
Mar 03rd, 2011, 7:24am
Does anyone have a block level (for ex, Verilog-A) model of a microprocessor? Or perhaps a data or a current vs. voltage plot of microprocessor performance from which a very simple model can be generated? The microprocessor can be Intel, ARM, anything.
Thanks.
Re: Interesting problem: Need block level model for microprocessor
Reply #1 - Mar 3rd, 2011, 9:02am
What are you looking for here? Can you explain the information you need better?
uP models are generally in Verilog or some other behavioral description, which does not have a detailed analog definition.
dtzihe
Reply #2 - Mar 3rd, 2011, 10:04am
Hi loose electon,
Basically, I am just looking for a very simple behaviorial model for a uP.  For example, how much current it draws for a given voltage.  I only need to see a uP as a black box.
Thanks for your help.
