Sep 10th, 2024, 10:14pm
track and hold THD issue (Read 2540 times)
ontheverge
Mar 04th, 2011, 11:45am
I'm simulating a flip around track and hold circuit as 1st  block for a 10bit pipeline ADC.  circuit diagram and output waveform are as below: when I measure the THD at A (differential) it's ~-80dB, however only ~-30dB at B.  all switches are bootstrapped ones and op-amp works fine (enough gain, no stb issue).
my questions are :
1. ideally, should A and B give the same THD ( A tracks and hold the input sinusoidal wave, B is either 0 or the hold value of A); how much degradation should we expect in practice.
2. how do i improve THD at B, which is actually the input of the 1st pipeline stage (other than impoving feedback switch)
Thanks a lot,
SteveEdited:
[edit]
[/edit]
boe
Re: track and hold THD issue
Reply #1 - Mar 29th, 2011, 8:14am
ontheverge,
How do you calculate the THD?
Note that at point B you have a sampled system. Did you take this into account?
B O E
