I'm simulating a flip around track and hold circuit as 1st block for a 10bit pipeline ADC. circuit diagram and output waveform are as below: when I measure the THD at A (differential) it's ~-80dB, however only ~-30dB at B. all switches are bootstrapped ones and op-amp works fine (enough gain, no stb issue).
my questions are :
1. ideally, should A and B give the same THD ( A tracks and hold the input sinusoidal wave, B is either 0 or the hold value of A); how much degradation should we expect in practice.
2. how do i improve THD at B, which is actually the input of the 1st pipeline stage (other than impoving feedback switch)
Thanks a lot,
Steve
Edited: [edit]
[/edit]
