Sep 1st, 2024, 5:36am
funtionality of this ckt (Read 2159 times)
ontheverge
Mar 07th, 2011, 10:40am
I came across these two ckts several times, just wanna lay out my understanding  and see if I'm correct or not.
for ckt (a) my guess is it's  to maintain the output when S1 was ON (instead of floating), and immune the output from noise and spikes,  similarly for (b)  if swiches are added in similar fashion
any suggestions are appreciated, thanks!
Steve
wave
Re: funtionality of this ckt
Reply #1 - Mar 7th, 2011, 11:11am
Steve - Read up on Latches and Flip Flops.
In b), consider the feedback inverter weaker than the fwd path.
~Wave   Cool
ontheverge
Reply #2 - Mar 7th, 2011, 11:29am
wave wrote on Mar 7th, 2011, 11:11am:
~Wave   Cool
Hi Wave,
u r right, (a) is d latch, by defintion it outputs signal when clk comes (here switch S1) and maintain the signal otherwise, so is what i said correct or I'm still missing the point, please clarify. and btw, what's the difference between this d latch and the more general one that uses two NAND (or XOR) ?
for (b) can you elaborate?  i'm a little bit slow
thanks,
Steve
