Sep 10th, 2024, 5:14am
Getting the INL from the DNL of an ADC (Read 7648 times)
Mischivis
Mar 17th, 2011, 7:38pm
Can I get the INL if I just know the DNL information of an ADC?
For example, if I have a 9 bit ADC and I know the DNL information
of the entire code (0.5LSB, 0.8LSB, etc.), can I get the INL from this?
boe
Re: Getting the INL from the DNL of an ADC
Reply #1 - Mar 18th, 2011, 3:06am
Mischivis,
Yes. The 511 DNL values of your 9bit ADC describe the step size between neighbouring codes, so you can determine the characteristic and the INL from it.
BOE
Reply #2 - Mar 18th, 2011, 11:44am
I know that this answer is in a dozen textbooks and on the internet as well.
Of course you can! the entire static response (Not dynamic) can be derived from the DNL, after all the voltage of each and every LSB step is in the data.
carlgrace
Berkeley, CA
Reply #3 - Apr 1st, 2011, 9:00am
Just add up the different DNL values to get your INL.  It is just the running sum (hence the term "integral").
Carl
Vladislav D
The Netherlands
Reply #4 - Apr 16th, 2011, 5:34am
I have a doubt. INL is an absolute shift of a transfer from the ideal one. DNL measures the ratio between an ideal and real step. So, if the whole transfer function is shifted, INL will change but DNL remains the same. I don't see correlation between INL and DNL in this case.
boe
Reply #5 - Apr 18th, 2011, 10:31am
Vladislav D wrote on Apr 16th, 2011, 5:34am:
According to common convention INL (and DNL as well) is measured against the best-fit line, so offset and gain-error do not affect INL.
Offset is not a non-linearity, so it should not be part of INL, whatever definition you use.
BOE
Vladislav D
The Netherlands
Reply #6 - Apr 18th, 2011, 1:05pm
Hi Boe,
boe wrote on Apr 18th, 2011, 10:31am:
I don't know about common convention but this is written in the book of ADI about the end point method of measurement INL:
"This is the most useful integral
linearity measurement for measurement and control applications of data converters (since
error budgets depend on deviation from the ideal transfer characteristic, not from some
arbitrary "best fit"), and is the one normally adopted by Analog Devices, Inc"
Offset is not non-linearity. However, offset causes non-linearity as well as second harmonic causes DC offset. Isn't it?
boe
Reply #7 - May 9th, 2011, 10:48am
Vladislav_D,
Sorry for the late reply.
Vladislav D wrote on Apr 18th, 2011, 1:05pm:
Offset is not non-linearity. However, offset causes non-linearity ...
No, but if you have a non-linear system, offset makes your non-linearity issues worse.
Quote:
... as well as second harmonic causes DC offset.
if an AC signal is present (in a single-ended circuit).
B O E
carlgrace
Berkeley, CA
Reply #8 - May 14th, 2011, 2:53pm
This is a situation where the application matters for the definition.  A lot of ADCs are used in situations (e.g. imaging, communications) where the absolute deviation from ideal is not important.  In those cases best-fit is the way to go.
To answer this question definitively, we need to specify the application.  Otherwise, we are just chasing our tails.
boe
Reply #9 - May 17th, 2011, 9:25am
Carlgrace,
I agree.
Vladislav D,
I found http://www.analog.com/library/analogdialogue/archives/43-09/EDCh%205%20sampling%.... Do you mean 1st paragraph on p. 5.15 (p. 17 of PDF)?
An offset shift will not affect the INL. Cf. Fig. 5.16 on previous page. If you shift transfer characteristics, you also shift dotted line, keeping the linearity error constant.
B O E
Reply #10 - May 18th, 2011, 6:05pm
carlgrace wrote on May 14th, 2011, 2:53pm:
Well stated!
