May 1st, 2024, 8:16pm
Sigma-Delta modulator: even order harmonic distortion (Read 8722 times)
matteo.tonelli
Mar 29th, 2011, 2:44am
I'm simulating a second order Sigma-Delta Modulator (Cascade of Integrators Feedback) with a 1.5 bit quantizer (3 quantization levels); a behavioural model has been implemented and all the simulations are performed in Simulink. The results are compared with the results obtained simulating Temes and Schreier toolbox and good agreement is proved.
The fft results in odd harmonics according to the odd quantization function and the noise floor is compatible with the expected value.
The fft calculation is performed using Hann windowing and coherent sampling (fin=fs*127/2^19, fft n.of points=2^19).
The power spectrum however includes unexpected even harmonics.
Since the model is perfectly balanced and ideal, why the modulator described above shows even harmonics? Is this problem intrinsic of the architecture?
Many works in literature show sigma-delta spectra with both even and odd harmonics but none explanation is reported.
Could someone help me to undertand the phenomenon?
Many thanks,
Matteo
View Profile matteotoons   IP Logged
Re: Sigma-Delta modulator: even order harmonic distortion
Reply #1 - Mar 29th, 2011, 6:23am
Matteo,
  Can you provide a plot of the FFT?
matteo.tonelli
Reply #2 - Mar 29th, 2011, 8:01am
Thank Sheldon for your attention,
the fft result (2^22 points, Hann windowing) is attacched.
Further details:
The oversampling ratio is 2048; the input sine wave is at fs*1023/2^22 where fs is the sampling frequency.
The 2nd order (cascade of integrators feedback)  modulator is based on a 1.3 bits quantizer; in other terms the quantization curve performs a mid-tread characteristic with three quantization levels
Thanks in advance,
Matteo
TraceTheLoad
Oregon State
Reply #3 - Aug 18th, 2012, 11:51am
Matteo ,
Are you applying a full scale sine wave as the input ?
Do you also see similar tones if you apply a smaller input , lets say -12dBFS ?
Praveen
